We’re excited to share Arkio 2.3, bringing major improvements to visual quality, mobile AR, and imported model workflows. This update makes it easier to experience your designs with realistic materials, explore projects at human scale, and interact with imported models across all Arkio-supported devices.
Here’s a look at what’s new!
More realistic materials with PBR
Imported models now support Physically Based Rendering (PBR) materials, bringing more realistic reflections, metallic surfaces, roughness, and material details into Arkio.
Our Revit, Rhino, SketchUp, and Archicad plugins can now export PBR material properties, helping preserve the appearance of your designs when bringing them into Arkio. We’ve also added new reflection environments for glass, metals, and other reflective surfaces.
Combined with improved rendering quality across devices, including higher resolution on Quest 3 and Quest 3S, your imported projects can now look better than ever.
Explore your designs with improved Mobile AR
We’ve made major improvements to Mobile AR, allowing you to experience your designs in the real world using just a smartphone or tablet.
New controls make it easier to place, scale, rotate, align, and lock your models. You can also teleport into your design to explore it at 1:1 scale, fine-tune its alignment with the real world, and return to previously locked positions.
Your AR placement is now preserved when switching between AR and 3D, making it easier to move between viewing and editing your designs.
More natural interactions with imported models
Movable elements and props can now collide with imported mesh surfaces, allowing you to slide, align, and snap objects against imported floors, walls, furniture, and other geometry.
We’ve also expanded our Archicad plugin with automatic placement, movable element selection, and PBR material exports, bringing its workflows closer to those available for Revit, Rhino, and SketchUp.
Discover everything new in Arkio 2.3
These are just some of the highlights! Check out our full release notes for more details, screenshots, and examples of the new features.
Read the full Arkio 2.3 release notes
As always, we’d love to hear your feedback. Let us know what you think of Arkio 2.3 and how you’re using these new features in your projects!
