Hi…I’ve been trying to find videos about the walkthroughs. Like I want to import a 3d from revit that I created a walkthrough i don’t know if arkio can do the same as walking from 1st to 2nd floor via stairs.
Has anyone tried any mechanical or electrical system being done on arkio.
Hi and welcome @guendalyn_yasol
You can check our support pages for videos and step-by-step instructions on how to load your Revit models to Arkio
In Arkio, you navigate around using the teleport tool in VR and your keyboard on a desktop or the on-screen thumbstick on touchscreen devices. Walking on stairs with gravity is currently not possible but you can teleport or pan around in VR to reach a higher floor or use the Q and E keys on the keyboard to move up and down in space.
You can model geometry on various scales in Arkio and import 3D models from various sources so you should be able to prototype some system layouts in Arkio but it’s likely easier to use specialized MEP tools for more detailed work and load those models to Arkio.
Let us know if you have further questions!
