Walking instead of teleporting
Hello,
I am new to Arkio, and I am learning the basics. So far I am loving the app but I find it dificult to move just by teleporting. I want to walk instead, not in reality but digitally. Is there a setting to change that?
Thanks you
Welcome to the Arkio forum!
You can move yourself around in Arkio using the grip buttons on your controller to pan forward/back. If you briefly grab and switch between two hands like a “ski pole” movement you can imitate walking to navigate your scenes without teleporting as you will keep a bit of momentum while throwing yourself.
In Arkio it’s possible to teleport through vertical planes (to allow you to teleport inside buildings and through doors) but this can be a bit tricky in complex 3D models so the grips give you finer control. We’re also looking into adding a dedicated fly mode in Arkio in the coming updates for users who are looking for an alternative way to walk around.
