A few questions, I’ve tried 1.7. The new UI for displaying certain settings on the wrist is very practical! And thank you very much for adding the large models, which will be very useful in my hypercontextualization system where I insert my point cloud mesh on m’y case.
Apart from 1.7, I made a few comments while testing this weekend
1 - I wanted to put my iphone on a tripod and film myself from an outside point of view designing blocks (for share content is better than always show a pov version)
but when I launched the AR mode on my iphone it put me with a camera far away and impossible to get closer to my position (cf photo)
i can only orient the model and change the scale. i understand that it’s not possible to synchronise the positions of my iphone in space, but it would be nice to be able to at least hand position the AR camera. Another problem that can be seen on the AR photo is that the floor is Arkio’s, so it would have to be transparent.
2 - It would be great to have an activatable mode on the arm that allows for creating without any interaction between blocks. Very often, one block sticks to another, and when I modify one, it modifies the other, or sometimes they stick together when I don’t want them to, etc. need a “free” mode where each block creation is independent, and blocks can intersect without causing a problem.
3 - Having the ability to activate block drawing based on a chosen orientation.
4 - Creating a block in space from the hand’s position rather than from the pointer’s position on the ground.
5 - Having a tool that allows for more precise orientation of a block using two reference points.
6 - AR mode shadows on the floor or on transparent blocks
Thank’s ![]()
