Hi,
I’m trying to model a few rooms in my home as i plan to remodel the house. Using the quest room import feature i can import one room at a time but i cannot see a way to import multiple rooms in a single scene
or failing that merge multiple scenes (rooms) together after capturing them individually.
Is it possible to do this in Arkio?
Hi Lonestar,
Welcome to our forum and good question. It’s currently only possible to import one room per scene in Arkio. If you want to model multiple rooms in one Arkio scene, you have to overtrace your additional geometry using Arkio’s main modeling tools using passthrough geometry. We plan to add support for loading more Quest scanned rooms in future updates.
You can also consider importing LiDAR scans made with an iOS device into Arkio or exporting your individually imported rooms to Sketchup, Rhino or Revit where you can compile the individual rooms into a full design of your house. Detailed models made in these other design tools can also be loaded back into Arkio if you want to collaborate or experience these designs in Mixed Reality.
Good luck with your remodeling, and let us know if you run into anything else. We’d love to see how it turned out and how Arkio helped! ![]()
