Hy, i have a question about the export from unity to Arkio.
In fact when i export my map with the textures from unity, it’s seems that they don’t appear on Arkio as the walls are all white.
is there something i didn’t do right ?
Thanks in advance
Thanks in advance
Welcome to our forums, Thomas.
Arkio’s Unity plugin converts your Unity scene to a GLB file for Arkio. You can also inspect this file for any missing textures at \Documents\Arkio\Import\Unity\
Only standard Unity materials/shaders are exported by the plugin, so if you’re using different materials/shaders in your project, they might need to be changed first. You can learn more about the Unity plugin and other known issues on our support page
If you like, we can also have a look at your exported files to see what the problem might be. You can contact us at support@arkio.is
Let us know if you have other questions about our plugins.
