Struggling with doors, windows and floors
Hi everyone! I’m working on building houses in Arkio using Meta Quest 3, starting with a floor plan in 1-1 scale.
I build all the walls relatively smoothly, but when I try to insert doors and windows the problems begin. With most of the basic door models, I either get a hole in the wall, or get only one side of the door. Similar thing with windows.
Also, it seems very hard to add a floor to the model, than can later be painted in some floor texture…
Is there a guideline, tutorial, or something where I can learn the best practices for this kind of actions?
PS: I have Arkio 1.8. Don’t seem to have the 1.9 avaliable. Also, applied for the Beta, but didn’t get a response yet
Hi Dario,
Arkio’s Doors, Windows and Walls are a bit buggy in 1.9 and got some usability updates for our upcoming 2.0 version that can currently be tested out in the Arkio Beta
These updates will be available in the live version of Arkio in the coming weeks and we’d love to hear if this makes it easier to work on your house design. Arkio should automatically update to the latest version on your device (currently still 1.9) but it can be that you are in a release channel and need to switch to the “Live” version from your App Settings under your app library and go to the Arkio store page to trigger an update/downgrade. The beta page has some more instructions on that.
When working on detailed 3D creations in Arkio you can best contain the walls, doors and windows inside hollow Arkio shapes. These shapes make it easier to move the attached geometry and make updates to your scene. You can also use the paint tool on only one face by selecting the face painting on your wristband.
A good example of this is the Sample Villa project that can be opened from the Arkio start menu. The easiest way to learn about creating more advanced Arkio creations is by taking these sample models apart to see how they were built.
Let us know if you have other questions.
